Old 1st June 2019, 08:07 PM   #1
Norman McCormick
Norman McCormick's Avatar
Default 17thC Sword, maybe?
A possible 17thC sword for your opinions. O.A. 37 1/2 inches, blade 31 1/2 inches, lenticular cross-section blade, weight 1 lb 15 3/4 oz.
Some things seem o.k. to me. Patina, no modern welding, chisel engraved decoration, running wolf suits time period, numeral font, springy blade, handles like a sword intended for use, blade still quite sharp with nicks where one would expect, tang peen and general feel. Cons, the date, although I have seen this on genuine pieces, the crisp engraving although again I have seen this on genuine pieces. Looking forward to your ideas.
Norman.
Old 1st June 2019, 08:11 PM   #2
Norman McCormick
More Photos.
Old 1st June 2019, 08:34 PM   #3
Norman McCormick
Another photo.
Old 2nd June 2019, 03:35 AM   #4
Norman, Im no expert on these things, I agree with you on the general crisp feel of the engraved numbers and wolf.
For me there is a crispness which seems to characterize the sword overall, which though very attractive, seems to have curiously combined elements.
These discs in the hilt guard remind me of similar seen on some Spanish, Italian and even Portuguese 'navigator' swords of 16th into early 17th c.
The striated escutcheon on the crossguard reminds me of similar features on some 18th c. smallswords. However all of these elements I cannot locate presently, it just seems I have seen them.
In the same way this resembles a mid 17th c. spadroon/rapier (plate VI, #22, "Schools and Masters of Fence", Egerton Castle, 1885) with simple guard system though not quite same, but pommel seems similar.
Returning to the engraved numbers etc. these seem inconsistent with these 'magical' themes which were popular in early to mid 17th c. These were not dates, but numbers with magic properties. It seems to me the '1' should be with serifs, and the other '1' seems intended to resemble a magic glyph or sigil which were often interpolated into inscriptions and sometimes numbers.
The 'anchor' seems unusually simple and atypical.
The wolf is of course similar to most examples seen and configured OK, but as these were freely chiseled rather than stamped, variation is expected.
The lenticular blade seems unusual, with blocked ricasso, for 17th c.
The wrap is remarkably crisp and sound, the turks heads seem cast?
Wire wrap of these periods seldom survives intact, examples I have had and seen almost always have this at least somewhat unraveled.
As I say, Im no expert, and pictures don't really give adequate feel for the actual item. You seem hesitant to declare this 17th c. and I am inclined to think it is possibly a 'historismus' item of 19th? The strange combination of elements etc. is my reason.
I hope I am wrong, and will be proven so, but I just have to be honest in my thoughts. To me its still a very attractive sword, and 19th c. weapons of these types are antiquities in their own right.
Old 2nd June 2019, 10:11 AM   #5
... You seem hesitant to declare this 17th c. and I am inclined to think it is possibly a 'historismus' item of 19th? ....
A pertinent approach, i would say, Norman . Others with more knowledge will concur ... or not.
Old 2nd June 2019, 06:37 PM   #6
Norman McCormick
Hi Jim and Fernando ,
Many thanks for your comments. A few further points, the Turks Head is made from individual strands, see photo, the crud of ages is giving the illusion of a homogeneous casting. The decoration on the blade and hilt all appears to be hand chiseled. As far as condition goes it does seem pretty good but I think we always need to be cautious re condition as some items do survive in very good order and although wear and tear can be a good indicator of age it is not a given. If indeed it proves to be a 19thC piece, which it may very well be, someone has gone to a lot of trouble to make a sharp flexible sword with very good handling characteristics and not a 'brick on a stick' as someone to aptly described a lot of the Victorian wall hangers.
Thanks again for your interest.
My Regards,
Norman.
P.S. My Elmar lens seems to be adding a little enhancement to the images. It's a bit muckier than the photographs would suggest. I also gave it a good wipe down with an oily rag to remove the surface muck.
Old 2nd June 2019, 07:05 PM   #7
Very pertinent, and as Norman has already intimated, there is a possibility this may not be 17th c. as by character, it does appear. As he has a most discerning eye, and formidable knowledge himself, I suspect he is of course simply seeking other opinions.
While we await those with knowledge in this field, I took the liberty of continuing my research to see if I could establish what influences and elements might be present in what my limited view compels me to think this is a pastiche of earlier swords.
This may well fall into the nebulous area of 'transitional' rapiers, which indeed were well known in the late 16th to early 17th century period.
In this time a style of fencing evolved in Italy and Germany termed 'spadroon' (actually an 18th c. English term for it) in which the swords were lighter and many of the moves different.
It is well known that English gentry was highly influenced by Italian styles and fashions in the 18th, into the 19th, and neo-classicism was prevalent in many cases. These elements often filtered into Germany as noted.
Egerton Castle (op. cit. pp.242-43) notes that 'shearing swords' ,very light ,were often used in England for swords used in this type sword play.
In looking into this shape pommel, Norman ("The Rapier & Small Sword 1460-1820", 1980), these oblate shape pommels (typically with capstan rather than peened) seem to predominate on late 16th-early 17th examples of rapier, as well as some left hand daggers. These seem invariably ornate, rather than simple with chiseled lines as here.
The example of 'spadroon' sword (pictured below)is a modern reproduction but with a shell and obviously of loosely similar structure as this, and accordingly light blade.
With the discoid elements noted throughout the hilt elements, I found in old notes a German ('fighting sword' as described) of late 16th-early 17th) which has these type roundels, though pierced. I thought them pertinent and posted the picture below.
Getting to the inscriptions, which as I mentioned seem crisp, and uncharacteristic of the talismanic inscriptions based often on magical glyphs, symbols interspersed with key numbers which were popular in first half of 17th c. These were often contrived with what appear Glagolitic, and even runic alphabet characters or interpretations of them.
The running wolf is placed as often characteristic within the numbers, which seem in most cases variations of 4's and '1' s but others do exist.
The wolf however, seems to be placed facing the reverse of most examples I am aware of....this of course is nothing conclusive but worthy of note.
(see plate from Wagner, 1967, below).
The other figure nearer the ricasso resembles what may be intended as a 'anchor' but more in the fashion of a magical glyph as mentioned.
These are the factors which have suggested to me this may not be 17th c as seems to have been the appearance intent, but perhaps a well made sword for someone following the traditions and neo classicism trends of late 18th into 19th c. The elliptical blade is something I have seen on military training swords of the 19th c. but not of course with a block ricasso like this. That is a characteristic of rapier blades, which were not as far as I know, elliptical.
I hope any of these observations might be useful, for me it just an exercise in learning, and I look forward to the elucidation of those knowledgeable here.
Old 3rd June 2019, 02:04 PM   #8
Norman McCormick
Having looked at past sales of items termed Riding Sword at Bonhams, Thomas del Mar and Christies numerals or 'dates' on blades seem to be more common that not.
Norman
Old 3rd June 2019, 03:27 PM   #9
Norman McCormick
I've had an opinion from a more learned member who is inclined to lean towards a later Victorian manufacture for this piece which of course was always on the cards. I'll continue to poke about the net to see if I can dig up anymore definitive info but for the meantime thanks to all for their input.
My Regards,
Norman.
Old 4th June 2019, 06:40 AM   #10
Norman
Thanks Norman, that has given me some good perspective on these dates.
As always, more research to be done.
Old 4th June 2019, 05:23 PM   #11
Norman McCormick
Hi Jim,
Always glad to give you something to do
For completeness a photo of the nicks in the blade at or very near the C.O.P. (sweet spot).
My Regards,
Norman.
