User Name
Old 19th May 2012, 07:13 PM   #1
Default Coloring epoxy putty
Epoxy putties usually come in a whitish/greyish color after mixing.
Do you know what kind of pigments is good to change the color and where can I get them?
Old 19th May 2012, 07:44 PM   #2
Location: CSA Consulate, Rm. 101, Glos. UK: p.s. - Real Dogs Have Feathering.
what color are you shooting for?
you can buy epoxy putty in various primary colors as well as black & white & mix them. steel, aluminum, copper & bronze colors also are out there.
if you are desiring to match wood colors, there is a co. that makes an epoxy wood putty that comes in various wood colors with a color matching chart to tell you how much of each to mix for a particular wood color.
googling might find what you are after.
if you already have the putty & are looking for powdered pigments to add, try an artists supply store for dry pigments. you may need to experiment.
the only colorants i've tried were powdered charcoal (from burnt toast & pulverised in a mortar/pestle) or powdered wood filings, but in clear epoxy. finely chopped colored nylon paracord mixed in to clear epoxy worked as a filler for something i tried once.
Old 19th May 2012, 08:45 PM   #3
Ferguson's Avatar
Send a message via AIM to Ferguson
Texas Knifemakers supply sells epoxy colorants, that I have used. They work well, and go a loooooong way.
Old 19th May 2012, 11:00 PM   #4
For better than 50 years I've used ordinary artists powder pigments to colour epoxies. Burnt umber is probably the most useful colour.
Mix the epoxy first, then mix in a tiny quantity of the pigment.
vB code is On
