19th August 2012, 10:33 AM | #1 |
Cannonball, or something else ?
This one was given to me by a friend. It was dug up in his garden in Aalborg/Denmark. It was found approx 70 cm in the ground.
Size is 11,5 cm/ 2254 grams. any thoughts on what it might be ? Thanks HB |
19th August 2012, 02:57 PM | #2 |
19th August 2012, 03:22 PM | #3 |
It is truly amazing to see what astounding information can be found with the search feature here! Over these years many informative discussions have brought together a great corpus of data in comprehensive coverage, often adding new and little known material.
19th August 2012, 08:43 PM | #4 | |
Unfortunately it seems like my ball is not a cannonball The two cirkles is excactly opposite each other and there is no filler hole sprue. Besides that mine is hollow. I have posted this on a danish site too, and noone can confirm this as a cannonball. Best HB |
20th August 2012, 01:54 PM | #5 |
Hi HB,
No wind mills in the area where your ball was found ? ... or prisons ? Look here: http://www.vikingsword.com/vb/showth...ht=cannon+ball |
20th August 2012, 05:43 PM | #6 |
Now you've had the serious replies...
It's a dead ringer for Mimas, one of the moons of Saturn. |
21st August 2012, 07:52 AM | #7 | |
Took another look at it yesterday. It seems like the dot in the circle has got a thread. So maybe it has been hanging from a hook/eye or something that has been screwed in the ball. It is most probably a counterweight of some kind. We didn't use those kind of windmills in Denmark, but it could have been used as a counterweight in another kind of industry maschine. Best HB |
21st August 2012, 10:00 AM | #8 |
as we just finished the olympics and are about to start the paralympics, the following comes to mind
2.5 kg throwing hammer/weight minus it's broken off handle? (some of these are hollow / lead shot filled.) Sarah Holt Throws the 2.5kg hammer Last edited by kronckew; 21st August 2012 at 10:32 AM. |
21st August 2012, 10:37 AM | #9 | |
now you have me worried. i have the feeling it will shortly clear the planet... |
21st August 2012, 07:40 PM | #10 | |
Incredible, how much alike they are ! |
21st August 2012, 07:43 PM | #11 | |
21st August 2012, 07:44 PM | #12 | |
2nd September 2012, 12:14 PM | #13 |
On a similar theme , I have had this odd item in my possession for 20 years .. it was dug up on a local farm and described to me as a cannonball by the finder. Whilst I doubt it's a projectile , I was hoping someone might recognise what it is . It has a diameter of 80 mm and weighs an astonishing 2.4 kg . It appears to be made of bronze but is hollow and filled with lead .
2nd September 2012, 12:53 PM | #14 |
A wall or a tower clock pendulum ? the suspension ring gone ?
