Old 17th June 2020, 08:50 AM   #1
Default Unusual Small Khukuri
Has a circular steel disk guard about 1 mm. thick & 5.4 cm. across. Wood grip approx.8 cm. long.
21 cm. steel blade is decorated, as is the wood scabbard. 4 mm. thick down to 3mm near the tip. 4CM wide at belly. flat spine with a smoothly curving profile.
Maybe a Ladies EDC or Gambler's concealed item? Razor sharp, took off a patch of my arm-hair no problem. A slicer, not a chopper.
Scabbard is nicely carved, has a large crack that appears glued, mint green braided sword binding near mouth appears varnished.
Humourous that I think of it as a tiny knife when it has a 21 cm (8.15 in.) blade.
