6th June 2020, 05:46 PM | #1 |
Indonesian( ?) short sword
Hello everybody,
I would like your opinion and knowledge about this item, It's not my area but it seems quite old ( 19th ?) and an authentic tribal piece, maybe indonesian ? it was sold as a sword but I find its quite small, 53cm / less than 21 inches long more a machete ?!? The hilt is made of wood maybe of horn with silver inserts ( and silver on the scabbard ? ) There is I think a missing piece at the end of the hilt. Glad if you help to fix it Kind regards |
6th June 2020, 05:54 PM | #2 |
It's a Karo Batak kalasan! The missing piece at the handle would be a silver sheet. Nice piece with an unusual handle. Regards, Detlef |
6th June 2020, 07:33 PM | #3 |
Thank you for fix it ! Do you think the hilt is a later replacement ? It seems horn but can be hard exotic wood |
6th June 2020, 08:03 PM | #4 | |
6th June 2020, 08:03 PM | #5 |
From what I can tell the Batak are mainly Christian/Muslim, yet the choil seems to be a shiva linga to me. Is there any more knowledgeable member out there able to amend my ignorance? Sorry for the pun.
6th June 2020, 08:09 PM | #6 | |
a strange ? interesting mix ?... |
6th June 2020, 08:47 PM | #7 | |
... a mix of differents cultures/symbols ... |
7th June 2020, 10:21 AM | #8 | |
Why? I really think that the handle is original, the motif/ornament on it is typical a Karo Batak motif. I've never seen such an handle before but I have no doubt that it's original to the blade. Regards, Detlef |
7th June 2020, 11:54 AM | #9 |
Hello Detlef,
The hilt and scabbard are very different in style and craftmanship. So I think the handle was added later. Which is not a bad thing persé. @ Francantolin, do you have a picture of the kalasan in the sheet, to see how the handle connects with the scabbard ? Best regards, Willem |
7th June 2020, 03:00 PM | #10 | |
I see what you mean. Maybe not the original scabbard? Best regards, Detlef |
11th June 2020, 04:27 PM | #11 |
Here some pics of the scabbard-blade, ( Not fast, time to receive it + problems with my login ) I see what you mean, sure it's not the same style but it fits pretty good in I have a second one and if I try to put it in the second scabbard it don't fit at all even if this blade is smaller... |
11th June 2020, 04:33 PM | #12 |
And the second kalasan ( now I know ! Still thank you Sajen !!! )
Nice hilt, sold as wood but clearly light horn. A ( nice ) classical model ?? Kind regards |
11th June 2020, 04:52 PM | #13 | |
Compare with my Batak knives. Regards, Detlef |
11th June 2020, 05:59 PM | #14 |
Really nice items !!
How long is the bigger ? ( mine 60cm-23,6 inches long ) I find my ''second one'' looks like the last on your picture. I have to clean ( not to much ) the silver parts make it a little more shiny like yours |
11th June 2020, 06:29 PM | #15 | ||||
Regards, Detlef |
11th June 2020, 06:31 PM | #16 |
Another Kalasan, horn grip, Aceh style. tight well fitted scabbard that matches the sword. 24in. blade.
11th June 2020, 06:43 PM | #17 | |
It's Batak style, the Aceh style is similar but different in fine nuance. Regards, Detlef |
11th June 2020, 06:46 PM | #18 |
Here the file work at my andar-andar, the example in down.
11th June 2020, 06:53 PM | #19 | |
11th June 2020, 07:00 PM | #20 | |
You can check it here by a drawing from Volz, tranlated from our member Roland. Regards, Detlef |
12th June 2020, 09:46 PM | #21 |
Thank you for the informative picture with the differents models,
So what do you think of my first model ? original piece looking like the number four with Tanke djembe hilt or a composite weapon with his all silver covered hilt and his matching scabbard with really different decorations/patterns ? Kind regards |
13th June 2020, 10:22 AM | #22 | |
Regards, Detlef |
13th June 2020, 06:36 PM | #23 |
I agree with you 100% on all you said Detlef.
13th June 2020, 08:50 PM | #24 |
Thank You !!
( especially for all precious comments ! ) Kind regards |
