16th May 2014, 04:18 AM | #1 |
Indonesian Utility Knife for ID
Hi Guys,
I picked up this knife recently and would like to know what it may be. The blade is chisel edged and quite well forged: gentle distal taper from 4.3mm-2.0mm. I feels good in the hand and would make for a good all-round utility knife. Thanks in advance for your thoughts, Russel |
16th May 2014, 05:59 AM | #2 |
Hello Russel, A quick question, does the tang extend all the way through the hilt and is then peened over on this piece? If it does I would guess that it might be from somewhere around the Bicol region of Southern Luzon. Photos showing more details would be of great help.
Best, Robert |
16th May 2014, 06:19 AM | #3 |
Thanks Robert,
No, the tang is partial. I will post a few more images soon. |
16th May 2014, 06:55 AM | #4 |
Hello Russel,
don't look Indonesian, I would guess that it is from the Philippines. Visayan, Luzon? Regards, Detlef |
23rd May 2014, 02:21 AM | #5 |
More images
Hi guys, here are a few more images. As you can see, the scabbard has some damage and loss, and has been glued together sometime in the past. Although there is no sign of it, am I correct in assuming it would originally have been held together by rattan?
As the images show, the tang is partial. The unfortunate hole in the handle allows a clear view of the tang, 2/3 the length of the handle. Thanks in advance for your thoughts and opinions, Russel Last edited by russel; 23rd May 2014 at 02:22 AM. Reason: Typos |
23rd May 2014, 04:55 AM | #6 |
Hello Russel and thank you for the new photos. To me the sheath looks like it could be from Bicol, but with the short tang and the chisel edged blade the overall look of knife kind of reminds me of a Ilonggo kutsilyo from the Western Visayas region. I'm sure that someone more familiar with these than I am will be able to give you a better idea of where this was made.
Best, Robert |
