Old 22nd April 2006, 09:51 PM   #1
Ferguson
Ferguson's Avatar
Default Philippine (?) spearhead for comments & ID
I was looking for khukuris on Ebay when I found a khuk, spearhead, and a puukko in the same auction. All my favorites in the same auction! How lucky is that? The spearhead looked promising, but I didn't get my hopes up. Pictures can be so deceiving. It looks Philippine? Moro? It's laminated, but the pattern is subtle. Thanks for any comments.
Steve
as received
Old 22nd April 2006, 10:09 PM   #2
Sure looks like a Moro budiak to me .
Old 23rd April 2006, 01:33 AM   #3
Lew
Lew's Avatar
Hey Steve that was a fast clean up job on the spear.It's a real nice budiak.
Lew
Old 23rd April 2006, 02:51 AM   #4
Ferguson
Ferguson's Avatar
Lew
Thanks guys. I HATE RUST!
Steve
Old 23rd April 2006, 05:05 AM   #5
panday
panday's Avatar
Here's another Budiak Spearhead
panday is offline   Reply With Quote
Old 23rd April 2006, 04:21 PM   #6
And another ...
I'm always amazed at how short the tangs on these blades are
Old 23rd April 2006, 04:55 PM   #7
panday
panday's Avatar
Rick, is that a twisted core spearhead? what a beauty
Old 23rd April 2006, 05:02 PM   #8
Hi Panday , I guess it is ; the veins of metal stand up a little ; you can feel them when you run your fingertip over the panel .
Best thing is that it's pretty much complete with ferrule shaft and tailpiece .
The head's a tad wiggly but I figure it's probably an old one .
Old 23rd April 2006, 07:23 PM   #9
Ferguson
Ferguson's Avatar
Rick, if it's not too much trouble, could you please post pics of the ferrule and the tailpiece? I was toying with the idea of mounting mine and would like to know what the ferrule looks like.
Thanks!
Steve
Edit: That is gorgeous! And Panday, thanks for the picture of your very nice piece.
Old 23rd April 2006, 08:30 PM   #10
Beautiful puppy Panday. Possibly an early budiak?
Old 23rd April 2006, 08:47 PM   #11
Arrow Too Much Work For A Sunday
Here you go Steve ,
The buttcap I added to ; originally this spear came with the two dark metal sleeves you see in the picture . The end of the spear had been drilled to accept a butt spike which was missing . I got lucky and found one on ebay made from brass ; to completely cap the end I bought a vintage brass 10 Ga. shotgun shell and drilled out the center ; the shell just fit under the original sleeves and the spike then went into the hole drilled through the shell casing .
It seemed to me a nice way to finish off an obviously incomplete end for the spear ; all pieces are vintage and could have been found in the Philippines in the 19th C. making it within the realm of plausibility as a treatment for this spear .
The ferrule is a casting and would require either a talented machinist to fabricate from brass stock or would need to be made out of jeweler's wax and fabricated with the lost wax casting method .
This budiak also has a waisted haft that swells at either end where it meets the fittings .
Old 23rd April 2006, 08:56 PM   #12
Question
Is that inlay Panday ?
Old 23rd April 2006, 09:35 PM   #13
panday
panday's Avatar
Yes Rick, that's an inlay, not sure what type of metal though, I was gonna say silver, but it's kind of reddish yellow, any idea?
Old 23rd April 2006, 09:38 PM   #14
Mmmmmmmm .. Suassa .
Really a beautiful point Panday !
Old 23rd April 2006, 10:05 PM   #15
Lew
Lew's Avatar
Hi Ferg
Here are two from my collection.The smaller one may help you with your rehafting project.
Good Luck
Lew
Old 24th April 2006, 02:50 AM   #16
Ferguson
Ferguson's Avatar
Nice inlay Panday.
Lew and Rick thanks! Those pictures are just what I needed.
Steve
Old 24th April 2006, 03:03 AM   #17
Ferg , you could easily make a ferrule like Lew's ; I would suggest using at least 6ga. Sterling sheet folded on the edge , formed around a ring mandrel and then soldered on a soldering mandrel while held together with iron wire .
Of course your silver sheet will have to be fan shaped in outline .
I'm willing to bet that Battara has the right equipment for this work .
I used to .
Silver is really fun to work with .
Old 24th April 2006, 04:12 AM   #18
Probably brass, perhaps with more copper than usual.
Ian.
Originally Posted by panday
Rick,
Old 24th April 2006, 03:19 PM   #19
pinoy
[QUOTE=Ferguson]I was looking for khukuris on Ebay when I found a khuk, spearhead, and a puukko in the same auction. All my favorites in the same auction! How lucky is that? The spearhead looked promising, but I didn't get my hopes up. Pictures can be so deceiving. It looks Philippine? Moro? It's laminated, but the pattern is subtle. Thanks for any comments.
Steve
Hi Ferguson, how much time did it take you to clean that spear head? Can you share how did you do it? I have some spears here which I am planning to clean then etch it after. Many thanks.
pinoy is offline   Reply With Quote
Old 24th April 2006, 06:00 PM   #20
Ferguson
Ferguson's Avatar
Pinoy,
I'll be happy to tell you how I did it, just proceed with caution so as not to ruin an antique. I spent about an hour cleaning and etching. My methods will probably not be approved of by some, and shouldn't be used on an expensive or rare antique without more knowledge than I have.
Since I was planning to etch, I wasn't concerned about removing the patina. It had active rust and some slight pitting. I started sanding with 400 grit wet-or-dry silicon carbide sandpaper. After I had cleaned off the rust, I continued with 600, 800, 1000, and 1500 grit. This type of sandpaper is sold at auto parts stores and is used to sand car bodies for painting. It works better wet. I use spray window cleaner that contains ammonia. The high ph of the ammonia keeps the steel from rusting quickly like water would. The liquid keeps the sandpaper from loading up. You have to be careful not to round off any of the edges. If I'm sanding a sword, I will use a small wooden block to sand flat areas. You also have to be careful around the edge. I've cut myself pretty badly before when I slipped.
Steve Ferguson
Old 24th April 2006, 07:50 PM   #21
Lew
Lew's Avatar
Steve Ferguson[/QUOTE]
Hey Steve
I see! Thats why they call you Four Fingers Ferguson
Lew
Old 25th April 2006, 01:07 AM   #22
Ferguson
Ferguson's Avatar
Lew, I've still got them all, they just look funny.
Steve
Old 25th April 2006, 05:14 AM   #23
pinoy
Thanks Steve, yeah I know how it feels like to be cut. I had my share of experiences.
Old 26th April 2006, 03:19 AM   #24
panday
panday's Avatar
Thanks Battara, this puppy will be paying you a visit soon
Old 27th April 2006, 12:35 AM   #25
Hello Panday,
I'm pretty sure that's really silver (alloy). I've seen this kind of yellowish "patina" with several blades (probably all etched with fruits) - one example would be this inlayed kris: http://www.vikingsword.com/vb/showthread.php?t=1243 (the uncleaned inlay looked even more brownish/dark-yellowish than the pics shown).
Old 27th April 2006, 05:54 AM   #26
panday
panday's Avatar
Originally Posted by kai
Hello Panday,
You're probably right Kai, I just finished comparing the tone of your Krises inlay to my spearhead's, they're about thesame.
Thanks,
panday
Old 27th April 2006, 06:18 AM   #27
panday
panday's Avatar
Btw Kai, how did that restoration on that Kris came out, can you post photos pls.
Thanks,
panday
Old 27th April 2006, 06:30 PM   #28
OH BOY, OH BOY, OH BOY!....
Old 27th April 2006, 06:32 PM   #29
Hello Panday,
Kai, you make a good point. Especially if the copper content is high, like in coin silver (80% silver 20% copper) or lower, the patina/tarnish can look yellow or even brown versus the usual black for sterling (92% silver 8% copper) or higher.
Old 27th April 2006, 06:35 PM   #30
Oh yes, and just for the halibut ( ) here is another spear head that I have mounted with my armour:
http://www.vikingsword.com/vb/showthread.php?t=1963
