Hi
,another recent acquistion....bought cheaply, thought originally by the seller to be wood. But after receiving it realised it was better than that...a hot pin test on shaft / ball confirmed the smell of 'burning hair' ....keratin Magnifying glass confirmed tubular grain at either end. Feels very 'grippy' .... even with a 'wetted' hand .....Rhino ??Carved crosshatching to handle end ...with a 'lanyard' hole bored using some sort of 'primative' drill, definately not by a modern drill. Old patina, OAL 22" ......is this considered a knobkerrie ?, Rhino horn for a drum stick seems to be a bit extravagent. Be very interested in other forumite's views, thank you Kind Regards David . |
#2 | |
KNOBKERRIES MADE OF RHINO HORN ARE TO BE FOUND IF YOU ARE VERY LUCKY. YOURS IS ABOUT THE RIGHT LEGNTH ALL THOUGH THERE HAVE BEEN LONGER EXAMPLES. IF IT HAS ENOUGH WEIGHT AND HEFT TO CRACK A SKULL I WOULD GO WITH KNOBKERRIE. I HAD NEVER HEARD OF DRUMSTICKS MADE OF IT BUT SEE NO REASON WHY IT COULD NOT BE USED AS RHINO WAS CONSIDERED TO HAVE STRONG MAGICAL AND MEDICINAL PROPERTIES BY MANY SOCIETYS AND DRUMS OFTEN HELD AN IMPORTANT PLACE IN THOSE TRIBES.
THERE SHOULD BE SOME OTHER POSTS MENTIONING THEM SO A SEARCH OF ALL THE ARCHIVES MIGHT TURN SOMETHING UP. CONGRADULATIONS ON A RARE FIND YOU LUCKY VARMIT
Hi David
It might well be rhino horn, it was used to make knobkerries in both East and South Africa, but they are rare due to the scarcity of the material. Objects made from this material tended to be reserved for chiefs and important people. Rhino horn was also occasionally used in axe handles. Difficult to judge from the photos, but from the curve (which follows the shape of the horn), could well be rhino horn - in which case many congratulations. Colin |
#5 | |
I think I should have made the reason for my comment more clearly . Agreed the drum was/is important to African culture. Rhino horn has certain characteristics that make it ideal for knife / sword handles ....princibly its 'grippiness' when wet with moisture (sweat) or blood ...so for any hand-held weapon it would be useful. I had searched for any examples of drum sticks made from Rhino.....but can find no reference whatsoever. All the 'knobkerrie' shaped drumsticks I have found in various Anthropological websites are wooden. Lovely drum that you posted ...certainly deserves a 'status' drumstick.Hi Vandoo, thank you for your comments .....although not big ( knobkerrie envy ....is there such a thing ) it would certainly make you 'see stars' ....the very slight flex in the shaft possibly adding to the impact 'energy'. I agree ......'lucky Varmit' ....a surprised one ....never thought that this could Rhino (only had pictures and had not handled it before buying)Thanks Colin, I am now 90% certain this is Rhino horn ..... I cant find similar sized examples .... can anyone post some. I remember Tim had a very good example, but was much larger ( knobkerrie envy.....again )Kind Regards David |
Congratulations David, certanly looks like rhino horn to me as well.
spiral |
#7 | ||
Unfortunately there seems to be little information on the web, regarding Rhino Horn Knobkerries. I would be grateful for any further info. Here is a similar example that has sold on Artzi's site..... "......A rare example of a Zulu Knobkerri war club carved entirely of Rhino Horn. It is 16 ½ inches long made from a beautiful piece of Rhino Horn with a 2 X 2 inches rounded nicely symmetrical head....." |
Other than the two examples that were sold on Artzi's site and a Rhino horn hafted axe ..sold at auction. I cannot find any others to help me value this for insurance purposes ie sold prices are not shown). If anyone has an idea as to approximate value could you please PM me.
I did find a reference to the the fact that Rhino horn was literally 'worth its weight in gold' (ref. dated 2005) ....at todays gold prices it would mean, for this knobkerrie, over £800 .....which seems far too much !! I hope I have not breached the rules (discussing possible value) Regards David |
Thank you Lew, Tribalarms and Rick (RSword),
for your PM's , very much appreciated. Kind Regards David |
David, I do hope this is R horn.
I do not want to take the wind from your sails, I have exprienced it enough myself and proofing your point though a PC is hard work. What one has to bare in mind is how large the horns of some African cattle are. The tips of Bovine horn are solid. I myself am unsure about the item. I like it and was watching it. One thing I can say is that as a form it lacks status and gravitas in its production, it is also rather short. |
#11 | |
Hi Tim, there is no bony core (evident in bovine horn), the 'knob' / handle end has an 'orange textured' surface. Hot pin test proves keratin. Using a 'wetted' hand' I can grip this as easily as with a 'dry' hand. I am sure that this is Rhino. " ...lacks status and gravitas in its production, it is also rather short" ....not certain what you mean. Both of Artzis examples have larger heads (one only slightly), mine is 1 3/4" x 1 3/4" (one of his is 2"x2") however, in length mine is the same as the longest ie 22", the other was 'only' 16.5". I cannot see any significant difference in their production Other than some Rhino horn 'hafted' axes I cannot found any other picture of similar knobkerries, if you have pictures of examples that have gravitas and status please post them, so that I can 'see what you mean'.All the best David |
Can you post a clear close up of the head side view and top view looking down. It looks like rhino but better pics will put the question to rest. |
#13 | |
will try, there is a build-up of 'patina' / darkening of both ends, it's easy to see the tubular structure when under the right lighting situation and using a magnifying glass. Will try and replicate in a photo. Regards David |
Hope these pictures are OK ....had to clean of some of the surface 'build-up' so that the structure is more evident.
The 'slot' cut in the upper most surface is something I had not really taken notice of before. This slot is not a split or damage, as I had first thought....now the area is cleaner I can see it was carved along time ago. I would say that the original 'concept' was undoubtably 'phallic' and a 'power' symbol Regards David . |
Most definately rhino
Congrats |
#16 | |
Thanks Lew ,I have read that you recommend mineral oil to 'condition' horn. Will it 'clean off' the patina ? The horn does seem a little dry but I do not want to lose too much of its age. As to the phallic symbolism, has anyone any comments or ideas .....a 22" phallus certainly would have gravitas....especially to the ladies Other than the scarcity of Rhino horn, symbollically the taking of such a power animal's 'weapon' and then re-working into the form of a 'human' weapon must have, in the eyes of the tribemen, made it incredibly 'powerful' and talismatic. Although the head of this knobkerrie is not massive, it does not detract from its functionality. A smaller surface area would 'concentrate' the power of the blow ....similar to a stilleto heel on a wooden floor ....the lbs per square inch is magnified. A skull fracture would likely cause haematoma...blood loss within the skull cavity....this bleeding creates pressure on the brain resulting in many complications and death. Interestingly, Zulu shamans were very aware of haematoma, and would 'drill' the patient's skull in the location of the head injury to 'release' the 'bad spirit' ....apparently there was a distinctive sound as the pressure was released Kind Regards David |
After re-viewing the close-up pictures I noticed a very precise line that encircles the head .....foreskin?? (
) Surely this must be phallic.Triple the power ??? Rhino/weapon/phallus (symbolic of male status) Regards David PS All 'school boy' comments accepted . |
#18 |
A light application of mineral oil will be fine and wipe off any excess with a clean dry cloth. Also renaissance wax is good to use instead of oil.
#19 | |
#20 |
Indeed very phallic which adds massive gravitas
Well done!! I missed that one
#21 |
MANY ORIENTAL SOCIETYS HAVE THE BELIEF THAT MEDICINE OR DRINKING CUPS MADE OF RHINO HORN WOULD INCREASE AND SUSTAIN YOUR SEXUAL PROWNESS. THIS WOULD COME IN HANDY IF YOU HAD MULTIPLE WIVES AND SLAVE GIRLS AND ESPECIALLY SO AS YOU GOT OLDER. THE ANCIENT AND FIRST VIAGRA AND UNFORTUNATELY STILL IN DEMAND TODAY RESULTING IN THE DECLINE IN RHINO'S AND ANTIQUE ITEMS MADE FROM THEIR HORNS.
PERHAPS THERE WERE SIMULAR BELIEFS AMONG AFRICAN TRIBES ALTHOUGH YOU DIDN'T HAVE TO GRIND IT UP AND EAT IT OR DRINK FROM A VESSEL MADE OF IT JUST HAVING IT AROUND, LOOKING AT IT GAVE ONE INSPIRATION ESPECIALLY IF IT LOOKED LIKE THE EXAMPLE YOU HAVE.
#22 | |
#23 |
Hi
I don't wish to be negative on such a rare piece, but I am a bit dubious about the "phallus" carving to the head of the knobkerrie. I have in the past seen similar embellishments done to wooden clubs and other tribal objects, to make them more "exotic" and enhance the value. Very easy to do and the application of some dirt etc., gives an old appearance. Difficult to be 100% sure either way, but still a good object. Regards Colin |
#24 |
Colin, I am not sure about phallic imagery being later additions. This item with three faces has a phallic element which is clearly not a recent adaption. The item is 53cm long. I believe these tri-face things are from Ethiopia. I am gathering information to back this idea, but will take a day or two to illustrate my thinking. It is quite possible that in the southern parts in the not too distant past Rhino were present. I could believe we might be looking at related items. There may be questions about the depiction of a foreskin regards to male circumsission. There was an early 80s band called the 4skins.
#25 | |
Hi Colin, thank you for your input, I can only say that IMHO the patina on this seems genuine. I bought this from a seller that does not sell arms, ethnographic items or antiques, and as far as I know was 'in the family' for a while.....a 'sleeper' in the true sense of the word. The dirt is too well ingrained and appears to be a build-up over time, rather than an application of 'one layer'. The horn seems to be quite old, and has suffered minor damage to the 'knob' which also appears to have occured a long time ago. I will try and find out further details as to how the seller gained possession of this object ....perhaps it would provide more details. Assuming everything is genuine.....would South Africa be a likely source of this knobkerrie ? Regards David |
#26 |
Hi David
Most likely the knobkerrie is from Southern Africa, the East African ones (rungus) tend to have a more pointed egg-shape, with a small collar or step below the head. In which case, your example could be quite early (19th century) as the Europeans managed to wipe out most of the wildlife fairly quickly... Colin |
#27 |
Just wanted to add this as it is quite interesting. It could also be a question, are these phallic stick clubs/batons possibly an Ethiopian tradition? I was hoping to include an ebay picture of the same three head motif on another stick only the size of a walking stick or staff but sadly I must have deleted it by mistake when clearing watched items. Here is a box, a suspect a snuff box judging by the black powder remains inside, carved as a bible. Look at the carved letters. The stick has one less but I think they are meant to be the same word. They are carved in the same manner but not by the same hand or in the same time. A coincidence the carvers having the same name? The name of a place of origin? I do not know but just goes to show one has to look far and wide for clues.
#28 | |
#29 |
You know I think you are right. I have been looking at Cyrillic alphabets. I did not know there were so many variations. I think I should start a new thread on this.
#30 |
I do not want to hijack Davids thread but I have just got to add this. These are old 18th century examples, I can show 20th century examples. There is a tradition of this sort of wood work. In one you see the same red and blue/black colour work. The head on the club/baton could some kind of holy trinity? is the script cyrillic? or an attempt at carving one of the two scripts seen on Ethiopian artifacts? The largest picture is Romanian and painted on glass.
