Old 19th July 2026, 07:37 AM   #1
Oiluj13
Default Help identify this piece
Greetings, forum masters and ethnographic scholars,I have an unusual acquisition on my workbench that defies standard textbook categorization. Rather than sharing my own research or chronological theories up front, I want to present this artifact completely blindly to the community. I am highly eager to get your uninfluenced, raw opinions on its geographic origin, timeline, and functional purpose.I have attached four highly detailed macro views from my workshop. Please dissect the following physical anomalies:1. The Spine & Face TopographyThe blade profile exhibits a broad-shouldered, single-edged trajectory that terminates in an acute, tapering point. However, looking down the spine axis, the steel maintains a massive, uniform, completely flat "I-Beam" architecture with zero tapering for the first half of its length. This blocky spine drops abruptly into an aggressive, one-sided single-bevel chisel grind. Under magnification, the surface reveals a clear horizontal micro-laminated, heterogeneous slag-bearing matrix crossed over by a dense, cross-hatched network of manual whetstone maintenance lines. Deep, stable historic pitting runs along the bevel boundary line.2. The Asymmetric Through-Bolt HiltThe mounting mechanism completely moves away from traditional blind-tang peening or organic resin seating. The hilt is engineered as a two-piece slab-grip scale set clamped over a wide, flat, full-profile tang. The fastening layout is distinctly asymmetric: one face utilizes two factory-machined, dome-headed slotted machine screws countersunk into the wood grain. The opposite face anchors into hand-cut, rectangular sheet-metal wash plates and sleeve-nuts/peened targets.3. The Hardened Leather SheathThe sheath is constructed entirely from a thick, hardened leather hide that has naturally crazed, water-shrunk, and oil-saturated over generations. The outer seam is held together by a tight, sequential row of heavy-duty copper/brass tubular eyelet rivets driven directly through the overlapping leather lips. There is no wood or rattan presence.The Challenge Questions:Based purely on the material mix and geometry, what is the precise geographic origin of this blade core?How do you reconcile the traditional asymmetric single-bevel chisel grind with a full-tang, slab-grip through-bolt configuration?Does the combination of the tubular scabbard eyelets and the factory slot-head machine bolts point to a specific historical conflict theater or supply line modification?I look forward to reading your blind diagnostic breakdowns and seeing where the metallurgy leads us!
Oiluj13 is offline   Reply With Quote
Old 19th July 2026, 11:26 AM   #2
werecow
werecow's Avatar
I can't comment on the metallurgy as I don't have the required knowledge base, but if it helps at all a reverse google image search came up with knives with a similar blade profile and canted grip and they were all listed on an Argentinian site that seems to be a local ebay variant (though it requires me to log in when attempting to click through, so I don't have more information than that).
Old 19th July 2026, 01:35 PM   #3
I like the backwoods or frontier look of this knife. There is an appealing rugged and functional quality to it. Interesting from your photos, having a chisel edge? Might help the identification.
Old Yesterday, 04:52 AM   #4
I don't know where this might have been made, but I do know that chisel grind blades have quite specific uses, as do blades that are set below the line of the hilt.
This is a fairly robust sort of knife, in a way it echoes the oldtime Saami knives that were used to take bark from trees. But this is not a Saami knife.
Chisel grind blades were (are?) popular in Siberia, this type of sheath construction is popular in Siberia, the hilt is rivetted & looks like cow horn.
Pure guess:- Siberia.
Old Yesterday, 03:25 PM   #5
wildwolberine
wildwolberine's Avatar
Default Sheep shears?
Hi Oiluj13,
Greetings from San Antonio!
Could this have been made from an old pair of sheep shears?
wildwolberine is offline   Reply With Quote
Old Yesterday, 07:11 PM   #6
Really good suggestion. To me the blade looks a touch to heavy?
