Old 19th December 2025, 07:57 AM   #1
Jayaningkurnia
Default Cypher? engraving on a Jogja pendok
Hello from a new member and greetings to everyone - am lucky and honoured to come across this forum.
I recently acquired a keris and had a new sandangan branggah made for it by a senior mranggi from Ponorogo. He gitted the sandangan with a perak lamen (old silver) pendok and I noticed there's a crown engraving at the back which piqued my curiosity (the attached picture).
Have any of you come across similar engraving before and does anyone know what does it signify/represents?
Thank you in advance for kindly and generously sharing your knowledge and wisdom.
Jayaningkurnia is offline   Reply With Quote
Old 22nd December 2025, 10:51 PM   #2
Good to see that you have another enquiry Jaya, & that you are maintaining your interest.
That engraving of a crown is simply an engraving of a crown, alone, & with no other symbols it really has no specific meaning. This is not uncommon.
If it had further engraving involving symbolism of the Ngayogyakarta Karaton, or of the Pakualamanan, it could indicate an association with a member of one hierarchies of either one of these noble houses mentioned --- or it might not.
I suggest that you might like to test, or to have tested, the material from which the pendok is made, this is a very simple test and usually a jeweller or silver worker will do it for free.
Alternatively you might like to buy a bottle of test fluid, it is quite cheap, lasts for a very long time, & a test takes only one drop. It is useful to have on hand when somebody offers you with a mamas pendok & claims that it is silver.
Old Yesterday, 04:28 AM   #3
Jayaningkurnia
Thank you Mr. Maisey for the input. Well noted on your advice to get silver test fluid for future purchases.
When I check online, most of these test fluids are acid-based and the process typically involves rubbing the silver on some form of abrasive surface (to be then mixed with the fluid for testing). Is this the test fluid you are referring to? and how do we avoid damaging or scratching the pendok?
