#31 |
This information came from British surgeons attending the wounded during the Peninsular wars and stated that penetrating punctures could rarely be fully repaired and the patients died, whereas cuts, ever dismembering cuts, could be far more successfully repaired.
The conclusion I came to was if greater attention was given to stabbing then greater death could be achieved. I have absolutely no idea what sort of weapons we are dealing with here. ps It was my understanding that bayonets were the main reason why swords became redundant. A Brown Bess with a 20inch bayonet is a formidable weapon, but it should have been backed up with a short cutting blade; unless you are Cavalry of course and I understand it is not sufficiently understood the degree that horses were used in WW1. Last edited by urbanspaceman; 28th October 2025 at 07:44 PM. Reason: ps |
#32 |
I'm going to have to take issue with Radbound's idea that a thrust is always quicker than a thrust.
For a smallsword or rapier held in a very point forward guard this may be true, but cut and thrust swords are usually held in a more upright guard and an effective cut is made by punching the hand forward and tightening the lower fingers while rotating the wrist to snap the sword blade onto the target. No it's not a massive cleave that will lop a limb off, but you don't want to make such an over committed cut that will leave you vulnerable if you miss anyway. The quick snap cut from the wrist often targets the forearm where any slice can be debilitating in a swordfight. By comparison a thrust from the same starting position would involve rotating the hand to bring the point on line before punching the hand forward, this meaning the hand covers exactly the same distance for a cut or a thrust. |
#33 |
My finale point on the cut vs thrust is always the report of an encounter between a French cuirassier and a dragoon of the Scots greys at Waterloo.
They charged each other and the Frenchman gave point and ran the Scotsman through. The Scotsman realizing he had taken a mortal wound rose up in his stirrups and brought his sword down on the Frenchman's head with such violence that both helmet and skull where split asunder. And they both fell dead upon the field! Here we see equally deadly results from both forms of attack, however if the cut had landed first the Frenchman would have had no reply. Equally the Frenchman was without defence since his attack had left his weapon stuck, if only briefly, in his opponent. And should the cut have landed upon the Frenchman's wrist before his point went home then the Frenchman would have been one of those survivors of the "less deadly" cut that made it to the hospital and lived. But the cut would have been a winning one by any measure of military effectiveness. The only worthwhile answer to the debate is that cut and thrust both have their place in a swordfight and a swordsman who has recourse to both has more options than one who must rely only upon one or the other. Robert |
#34 |
Yes, isn't that Peter's point?
#35 |
G'day Guys,
Some examples from my collection of 19th century sword cutlers playing with the design of cutting swords to make them better at thrusting. Cheers, Bryce |
#36 |
Hi Keith... Exactly...The streetfighter in a bar room melee has more resources to use whereas the more conventional opponent in a boxing match follows recognised set moves and responses... What was needed was a sword armed technique which incorporated those moves used in brawling...The unconventional strike, the smash to the opponents face with the pommel...thus a no rules barred open minded free fighting technique /winner takes all approach. The arguement comes in when sword style becomes the focal point or when fieldcraft ...painting the sword black appears... but its probably a smoke screen... It was all to do with the training where the emphasis was on sword fencing instead of Sword Fighting..
Regards,Peter Hudson. |
#37 | |
Regards, Peter Hudson. |
#38 | |
What I would suggest here is that no matter how much design was being applied on blade style; much of which ended off being part of an arguement on cutting or giving point simply evaded the issue ...and the real concept fault was on technique of training...in the melee where all moves must be allowed...although if you follow my thoughts on this it becomes more obvious that the more facilities you have on your sword ...and in your head to damage your opponent by hook or by crook... and by whatever fighting skills you can use is the essence of how things should have been applied. My way of looking at an Officer on the battlefield would have been as a gun platform with two pistols both on lanyards plus a sword with all sharp edges and with a spearpoint and spiked pommel...and at least one fighting knife or bayonet. and a couple of grenades...and Trained to Fight not Fence. Regards, Peter Hudson. |
#39 | |
Robert |
#40 |
It is baffling to me that there were two very distinctly different swords; essentially the Spike form with IBeams and designed to stab/run through targets and to solidly block incoming strikes... and the more classic Cut and Thrust typically cavalry weapon...so that logically a lesson on both swords, though different in content, could be easily added to with the required techniques to turn the concepts into fighting skills. However I have not the faintest idea why this never transpired and as we know the baby went out the window with the bathwater !!...
It goes without meaning, for example, to have Rifle range zeroing and the various range practices and classification at different ranges from 100 out to 600 yards..yet no fighting skills through field firing exercises....and sniper training in battlefield conditions. It was as if sword fencing or the training of it, had frozen its self solid! As a matter of interest I was looking at pistols and other personal weapons used by what is now used as skills for skirmishers...used in close quarter battle drills particularly in fighting in built up areas....and that there was a large, essentially available list of pistols and even twelve bore shotgun trench clearing specialist weapons being used in WW1.so that the suggestion to return swords and carry a swagger stick seems just mind boggling!!! The plot thickens. Peter Hudson. Last edited by Peter Hudson; 29th October 2025 at 03:59 PM. |
#41 |
While there is similarity between Scinde Cavalry hilts, 19th C British Officers Infantry Sword hilts and the Paisley Tie Design it appears that the Cyprus tree gives the Tie Design and the Icanthus the Cavalry Hilt... both Indian designs ...and both very similar.
Both the 19thC British Infantry and The Scinde Irregular Cav hilt shapes are very very closely similar in general shape but the cut floral application is distinct in each but this does not make it any easier to unscramble, however, if something pops up to clarify this bit of the puzzle I will note it for the thread. Meanwhile I am collecting a pipeback quillepoint Scinde Irregular Cavalry Sword in a few days and should have mastered how to use my new camera by then so illustated pictures can be seen on thread soon.. Please add your 19th C. British swords to thread and feel free to comment.. Regards, Peter Hudson. Last edited by Peter Hudson; 29th October 2025 at 03:50 PM. |
#42 |
While the similarity between Scinde Cavalry hilts and the Paisley Tie Design it appears that the Cyprus tree gives the Tie Design and the Icanthus the Cavalry Hilt... both Indian designs ...and both very similar.
Both the 19thC British Infantry and The Scinde Irregular Cav hilt shapes are very very closely similar the floral application is distinct in each however this does not make it any easier to unscramble...but if something pops up to clarify this bit of the puzzle I will note it for the thread. Meanwhile I am collecting a pipeback quillepoint Scinde Irregular Cavalry Sword in a few days and should have mastered how to use my new camera by then so illustated pictures can be seen on thread soon.. Please add your 19th C. swords to thread and feel free to comment.. Regards, Peter Hudson. |
#43 | |
A Scots Grey 1796 disc hilt from Waterloo. Heavy and deadly. |
#44 | |
About a hundred to one hundred, fifty grams heavier than the 1796 Pattern light cavalry troopers, but lighter by the same amount to the French An XI light cavalry sabre and nearly three hundred grams lighter than the AN XIII Sabre of the line. |
#45 | |
Cheers, Bryce |
#46 |
Officers were a snipers target, wearing a sword was like waving a red flag. I can't recall the reference to this, there was a British officer wearing his sword engaging a German soldier, but as he got to him he decided to kick him in the groin. He said something like it was not in the best military tradition but quite effective.
#47 | |
Peter Hudson. ps. However ...I need a new camera as my old one is kaput!...and I need to rattle on and get .some pictures of 19th C British Infantry Officers Swords ...anyone else is invited to send it theirs .I am sure there are lots. |
#48 |
John Jacob designed the double barrel cavalry carbine in 1854, but it was apparently somehow destined for South Africa. That same year, through requests for supply from the Malabar Police in India, these went there instead. They ended up issued to the 12th Lancers who were posted to Madras.
The East India Company acquiring these with Jacob designing the unusual sword bayonet which was to be attached to these. The EIC contracted with S Swinburne & son to produce these. While an interesting concept, it was apparently found these were more effective as short swords than with the use in bayonet manner. While the bayonet in less cumbersome design remained effective, later sword types were shorter and better suited for use at the end of a rifle. Infantry continued with the bayonet instead of the sword, while cavalry still maintained the sword for some time. I agree with Peter, if more attention was paid to innovative officers who understood the requirements and more effective application of tactics and weaponry in accord with the circumstances in which they were to be employed, far more effective results would have resulted. There are countless records of military blunders and disastrous outcomes which came from narrow minded adherence to misguided rules and regulations. Situations are dynamic and volatile, and not 'one size fits all'. |
#49 |
Here is Osborn and Gunby's attempt to produce a serious cut and thrust blade. Known to collectors as the "Osborn and Gunby blade".
Cheers, Bryce |
#50 |
Some really super swords being shown in this thread.
#51 |
Hello Tim , I quite agree , in fact these exhibits are the best I have ever seen including the weapon being studied which when fired ...ranged at 2,000 yards must have been incredible.
Regards, Peter Hudson. To which I add; A British, Jacob’s Double Barrel Rifle Carbine, From The Early British Raj. Period. In fact the weapon I speak of was an experimental version and rather a special one off piece but it was very similar and I thought to include the write up... The gun is the very inspiration for the famous Military Jacob's Rifle, used by the Scinde Irregular Force, Jacob’s Rifles, in the early 1850's, and this was commissioned for an officer of the regiment. A writer of the period described shooting a rifle of this form: “The recoil is by no means pleasant. Jacob recommended a powder charge of some 2 drams 68 grains of gunpowder! This rifle does not seem to have any advantages at sporting ranges; but for military purposes it has been strongly recommended. Especially in reference to the explosive shells which are used with it. The shells require a short stout barrel, and cannot be used with a long thin one, like the Enfield still, Enfield-style rifles were actually manufactured with Jacob rifling, and seemed relatively popular. For killing large animals, like the elephant or rhinoceros, they are particularly qualified; and I should strongly recommend elephant hunters to examine the merits of this rifle. This rifle was made to accompany the howdah pistol as the big game hunting rifle to be equally at home on foot, on horseback or while standing in a howdah on one's elephant. But also for perfect use in Indian irregular cavalry by gentlemen officers. The Jacob's rifle was designed by General Jacobs of the Honourable East India Co. who was so admired and respected by all who knew him, for his intelligence and skill of command, he had a city named after him, in modern day Pakistan, called Jacobabad. He had spent 25 years improving rifled firearms, carrying on experiments unrivalled even by public bodies. A range of 200 yards sufficed in cantonments, but at Jacobabad he had to go into the desert to set up butts at a range of 2000 yards. He went for a four grooved rifle and had numerous experimental guns manufactured in London by the leading gunsmith George Daw and completely at his expense. Jacob, like Joseph Whitworth, was renowned not only as a soldier but as a mathematician, and his rifle was as unconventional as its designer. Rather than using a small .45 caliber bore Jacob stayed with more conventional .57-58 caliber (Bill Adams theorizes that this would allow use of standard service ammo in a pinch). In any case his rifle used four deep grooves and a conical bullet with corresponding lugs. Though unusual the Jacob's rifle, precision made in London by master gunsmiths like George Daw, quickly gained a reputation for accuracy at extended ranges. They appealed in in particular to wealthy aristocratic scientists like Lord Kelvin, who swore by his. Jacob wanted to build a cannon on the same pattern, but died early at age 45. A few Jacob’s were used during the American Civil War, and those were privately owned, usually by men able to afford the best. There is one account of one of Berdan’s men using one (the chaplain, Lorenzo Barber), who kept one barrel of his double rifle loaded with buckshot and the other with ball. Jacob's Rifles was a regiment founded by Brigadier John Jacob CB in 1858. Better known as the commandant of the Sind Horse and Jacob's Horse, and the founder of Jacobabad, the regiment of rifles he founded soon gained an excellent reputation. It became after partition part of the Pakistani Army, whereas Jacob's Horse was assigned to the Indian Army. A number of his relatives and descendants served in the Regiment, notably Field Marshal Sir Claud Jacob, Lieutenant-Colonel John Jacob and Brigadier Arthur Legrand Jacob, Claud's brother. As commander of the Scinde Irregular Horse, Jacob had become increasingly frustrated with the inferior weapons issued to his Indian cavalrymen. Being a wealthy man, he spent many years and much money on developing the perfect weapon for his 'sowars'. He eventually produced the rifle that bears his name. It could be sighted to 2000 yards (1 830m), and fire explosive bullets designed to destroy artillery limbers. It also sported a 30 inch (76,2cm) bayonet based on the Scottish claymore. Jacob was an opinionated man who chose to ignore changing trends in firearm development, and he adopted a pattern of rifling that was both obsolete and troublesome. Nevertheless, his influence was such that during the Mutiny he was permitted to arm a new regiment with his design of carbine. It was named Jacob's Rifles. Orders for the manufacture of the carbine and bayonet were placed in Britain, and all was set for its demonstration when Jacob died. In the hope the East India Company would honour the order, production continued for a little over a year. |
#52 |
More detail here..https://www.royalartillerymuseum.com...-sword-bayonet
Peter Hudson. |
#53 |
Old notes, found this:
From "Charge to Glory", James Lunt, (1976) p.1: "...the charge will always remain the thing in which it will be the cavalrymans pride to die, sword in hand". -Cavalry Journal, 1909. He dedicated the book to his friend, Capt. Arthur Sandeman, of the Central India Horse, who died leading a contingent of about 60 mounted sowars of the Burma Frontier Force in the last mounted cavalry charge of British cavalry on March 21, 1942. On patrol at Toungoo, Burma, which was the site of the airfield for the famed American Volunteer Group (the 'Flying Tigers') , seeing a body of military they first mistook for Chinese, then realizing it was Japanese infantry who opened fire.... Capt. Sandeman instinctively raised his sword, the over 60 sowars, mostly Sikhs, charged , in the old style with sabers. He and most of the sowars were killed, |
#54 |
Coming late to this, during the C16th and C17th the rapier was indeed noted as being unmilitary, being too long for the battlefield and unable to pierce any form of protection.
However, one reason the introduction of the rapier for use by gentlemen was initially condemned was because a thrust through the body was invariably fatal whereas cuts from broadsword and backsword blades were often survivable. Masters of Defence were expected to prove their mastery via fights with live blades and the 'swashbucklers' would fight with live blades and both would live to tell the tale. Work by Dr Ismini Pells on pensions claimed and issued to soldiers of both sides during and after the ECW / BCW / WOTK showed that only 4% of those claiming pensions (usual health warnings etc) were due to sword injuries. From that we can either deduce that swords were rarely used (unlikely for example given the preponderance of cavalry during that era and the contemporary accounts of stormings) or that swords rarely inflicated debilitating injuries. I incline to the latter, suspecting that many wounds were treatable cuts. |
#55 |
Hello Triarii, well its all confusing and to many its all rather not worth arguing about but the upshot was that swords in the context of serious conflict weapons ...ie WW1 in 1914, were off the battlefield. So really it makes no difference which style was used... They all went home.
...To us this was a catclysmic end to the whole business of collecting and history of weapons...Other than for parades and ceremonial duties...apart from the odd individual military action...the sword was finished...and the corner was turned in favour of gunpowder weapons...and associated weaponry like Bayonets. Swords continued and indeed were diverted to be used in wars further afield like in the orient and in other spheres like in India...The amazing orders to get swords off the Battlefield and replace them with swagger sticks to one side...sub units were reorganised to replace the sword including the use of shotguns and pistols etc. The American soldiers developed a useful pump action shotgun they knicknamed The Trench Broom. and there were some useful revolver and magazine fed pistols as a backup weapon...and the use of cavalry moved apace to include the use of Mounted Infantry using shorter barrel carbines etc. However having said all that ... I still think it worth considering what blades were being used at the time and how was sword design handled up to its sudden demise. Indeed I think the period during which swords were removed from the battlefield spans a vital opportunity to view the many blade styles that aoppeared in our historical record. There was a bounceback of styles covering hundreds of years of sword development...As an example look at the 1821 pipeback which was redesigned with a solid backblade in 1845 and with a huge fuller and retaining its spear point...and for use up til the end of the 19thC. The old 1821 wasnt simply ditched but went on to be purchased for Indian Cavalry such as The Scinde Irregular...Jacobs Horse...while at the same time blades of every shape size and style appeared.as if the late 19th C.was being held up as a mirror for all things Sword Style...and yet just around the corner it was all about the come to a halt! Thus its important place in our study I think. Regards, Peter Hudson. |
#56 | |
As to the other questions, changes in warfare and technology are largely to blame. I would say that cavalry was far from useless in WWI when it COULD be utilized in the proper way. I think the difference is that cavalry vs cavalry and cavalry as a breaking attack largely died. The speed in reloading is probably the biggest factor for the latter. While you can or could overrun a position with cavalry, the infantryman being able to fire off even 3 or 4 shots in the span of 40 seconds rapidly decreases the advantage the speed of horse provides. But cavalry as skirmishing and pursuing a rout/following up targets of opportunity was still a viable tactic. And for that, stabbing from horseback is much easier. As far as the form of blade in the late 19th century through 1918, Britain was far from alone. The images attached are of the British 1912 sabre which I am sure you recognize, but also include others from the ~30 years prior up to 1914. In order: -British 1912 -The French utilized the 1896 cavalry sabre, albeit unsuccessfully due to a weak blade. -But alongside that was a very rare experimental model with a different grip. -Next, there is an exceedingly rare Prussian/German 1888 trials sword, with a rebated steel bowl guard, a canted grip with a thumb placement, and a straight blade. -A Swedish 1893 cavalry pallasch and what I feel is the best sword in here. At ~1-1.1kg, it is far and away also the lightest and a rebated guard and even more robust blade with excess mass for rigidity would still make it quite light. As it is, it still has the most classic cut and thrust profile, of a form that goes back to 18th century Sweden and earlier -The US 1913 Patton Sabre which is my least favorite (grip is too large and squared, the POB is too far forward to be an effective thruster but the blade is too narrow and too thick/canular to be an effective cutter as well) which rightly gets compared to a 1908/12 and a Swedish 1893 but I think a bit of credit must also be given to the French as Patton studied at Saumur cavalry school as well -A screenshot of the 1895 series of Dutch cavalry sabres from the following article which I highly recommend: https://www.huzarenvanboreel.nl/wp-c...etherlands.pdf -And a later Italian officer's sabre, although it should be noted the Radaelli/Del Frate type of officer-dueling so popular in Italy especially when Barbasetti proposed even more straight swords is likely more to do with Italian blade prefrence I apologize if this appears to be off topic, but the point I am attempting to make is less that Britain alone decided to go from the 1896 Universal pattern of cavalry sword, of which I generally am a fan of depending on certain things (later grips were too straight and narrow and the guards tended to be thinner and less protective IMO). But moreover, that the late 19th century through the start of WWI saw almost all of the major powers gravitate towards a sword with the following characteristics: -A larger, symmetrical or mostly symmetric bowl guard -A grip that was optimized for a thumb-on-back grip (the italian 1888 for example has a cut in the guard and the grip ferrule has a flat piece that slots over the opening so when assembled it forms a protected slot for your thumb) -A blade which is optimized for the thrust primarily Not every country or model of sword followed this, the Swiss 1896/02 (my first combat sabre), the British mountain artillery, SOME German swords, and the Norwegian 1888 all have more classic compromise blades. But if I may offer some sort of suggestion as to the mindset, or at least my interpretation, it is this: the change in sword in this period was not necessarily to make them ineffective in combat, but to redefine the mode of combat. Less for "fighting" and more for "killing." Which I admit sounds a bit edgy, but when you look at accounts of the Boer War and WWI examples in which cavalry did engage either on the Western Front, Mesopotamia, or other areas, there was relatively little hack-and-slash fighting but extremely abrupt bursts of high intensity movement. Anything else and you run the risk of getting shot from being stationary. As such, the optimized form of sword does favor something that can quickly stab through a chest, be withdrawn, and on the move. As Matt Easton and others have said, it is paradoxical that it is easier to train men to go for a thrust, but when given no training, your first instinct is to use any item of length more for bludgeoning/cutting. I would posit some level of thinking along the lines of "cuts can be fatal, but proper edge alignment, sharpness, follow through all must occur, alongside the enemy having nothing on their body that can arrest the momentum of the cut such as webbing, bandoliers, or other things let alone deliberate protection makes cutting much less certain than seeing a piece of steel emerge 20cm out the other side of their body." I think the comparison of these blades as so-called 'hand lances' really sells it. Largely, the sword is the only weapon in which romanticized notions of back and forth fights, sword against sword, man against man, have endured. The sword did not stop being a weapon, but it went back to ONLY being a utilitarian tool optimized for killing. As to the hilts, there are a few parallel origin points: -The honeysuckle hilt is an evolution of an earlier Austrian pattern I believe, similar to the 1796 LC and HC writ large. -The acanthus hilt is derived from the Scinde Irregular cavalry -The 1788 and others also share lineage from early modern Walloon or Mortuary hilted swords around the English Civil War I know there were other rare and experimental hilts trialed, but we only have scant records on them unfortunately. Some units, especially the Yeomanry and Northwest Frontier units did have special patterns. I believe it was in Robson or Latham that one of the Yeomanry units was noted to have a half-basket from a list of regulation patterns. While it might be believed that this was just shorthand for the other bowl guards, they alone have this wording on theirs and it makes me curious what it might have been. As an entirely unnecessary addendum, I feel that the best possible sword to meet these design goals would be taking the hilt of the German Trials sabre alongside possibly the grip or a more neutrally oriented (left vs right) and more canted 1912 grip, and the blade of a Swedish 1893, modifying it to be ~10mmx35mmx95mm at the base, and giving it a wicked hollow grinding. I also have a French pre-1882 Colonial sword with one of the canular/Z-shaped fuller/diamond cross section blades I find to be all but perfect, floats in your hand almost despite a 950g weight due to proper shaping, but is utterly stuff with the thin edges and width allowing for good cuts, it is my single favorite sword I own despite arriving covered in rust and costing me 260 euros in 2021. It is the last image and frankly even giving this a more symmetric guard and canted grip would make it damn near perfect and easy to manufacture. |
#57 |
Hello Magey_McMage,
Thank You for your excellent post, I was just reading the following on the web and place it here for reference... https://www.antique-swords.co.uk/184...e-sword-blades. Regards, Peter Hudson. |
#58 |
Please see https://www.fordemilitaryantiques.co...lkinson-latham
The above detail gives superb background on the subject at post. It can also access part 2 and 1 on the same authors detailed research . I am about halfway through putting together a quite large Post and I think the information here will throw a light upon this complex subject. Regards, Peter Hudson. |
