Greetings everyone,
I am opening this standalone thread to seek the community's insights and regional expertise regarding a specific structural theory on this dagger asset. When looking at the complete assembly, the incredible, highly precise geometric symmetry of the repoussé scabbard and the hand-chiseled bi-metal hilt clearly indicate a high-status item commissioned for military gentry or aristocracy. However, the blade flat itself appeared surprisingly plain given the intricate craftsmanship of the furniture. To investigate the underlying metallurgy, I polished a section to a raw baseline and executed a localized control etch using a mild organic coffee solution. The etch revealed a prominent, latent vertical "tiger stripe" macro-segregation pattern running continuously beneath the sanding scratches. This dense, columnar carbide segregation suggests a large, slow-cooled ingot steel profile. My working theory is that this blade may have originally belonged to a high-performance historical sword that was broken or damaged in the field, which was subsequently salvaged, re-tipped, and recycled into this high-tier dagger configuration by a court metalsmith. I would love to open the floor to your opinions: How common is the reuse and re-hilting of broken or cut-down sword blades into daggers within your respective areas of study? Does this vertical columnar segregation matrix or the specific hilt/scabbard artwork point to a particular regional workshop or historical conflict era where this type of recycling was practiced? Looking forward to your thoughts and any cross-references to similar salvaged pieces in your collections! |
I'm sorry to disappoint you, but I don't think this is a high-grade blade or dagger. It is a classic, basic Chinese/Tibetan (possibly Mongolian) dagger, most likely produced in the mid- to late 20th century. The simple flat blade is consistent with the hilt and scabbard, so everything appears to match. To answer your question, however, old sword blades were sometimes repurposed and reused to make daggers. South Indian katars, for example, occasionally incorporate recycled sword blades.
Though I could never prove it with this image, both of these blades are wootz.
The straight one on top, now a Kurdish kard, clearly started as the forte of a very high quality 18th century Persian shamshir and retains gold inlaid cartouches confirming the pedigree. The defect visible near the tip reflects an artifact of the technique by which these blades were forged (per Manfred Sachse: Damascus Steel). The blade of the curved one below I have suspected began as the tip of a shamshir, though there is no evidence beyond the overall form to confirm this. |
Thank you all for this exceptional, high-level commentary! Lee, your legendary eye for historic crucible steel structures is completely unmatched [𑀓].You noted that an image alone couldn't definitively prove it, so I took your cue and moved straight past speculation [𑀓]. I spent the morning at a local industrial engineering foundry running an official stationary laboratory analysis across the prepared bare-metal control window of this specific piece.The machine utilized for this evaluation was a permanent, laboratory-grade Bruker Spark Optical Emission Spectrometer (Spark OES) running Bruker’s high-performance QMatrix evaluation software.As shown in the attached certified printout, the hard chemical data completely rules out modern recycled vehicle spring steel or mass-industrial junk:Manganese is extremely low at 0.380%: Standard modern 20th-century spring steel (like AISI 5160 leaf springs) requires a high, factory-controlled Manganese level between 0.70% and 1.00% to ensure uniform mass hardening. This low, organic 0.380% level points directly to a pre-industrial historical melt where manganese only exists as a natural trace element from the original local ore deposit [𑀓].Chromium is completely absent (<0.100%): Modern industrial recycling always carries widespread, muddy chromium alloy contamination. Having zero chromium mathematically proves the blade contains no modern recycled automotive scrap elements.The Carbon Calibration Ceiling (<1.500%): As the foundry technician, Matt, explained on-site, the machine's software routine literally could not calculate a smooth, standard decimal for the Carbon, forcing the printout to flag at its default program threshold of <1.500% [𑀓]. Because commercial foundry units are calibrated for homogenized modern alloys, the intense microscopic carbon crystallization segregation (Wootz) in this antique matrix threw off the software's averaging algorithms [𑀓].High Purity Baseline: The iron content registers at an incredibly clean 97.79% Fe, featuring only raw, native mineral trace elements (like 0.037% Nickel and 0.013% Vanadium) with zero modern chemical additives [𑀓].Pairing your definitive visual identification with a certified Bruker OES chemistry receipt proves we are looking at an authentic, ultra-pure, high-carbon historic crucible melt hiding right under the patina!
#5 | |
Nobody has suggest automotive spring steel for this blade, the notable thing about it is the carbon, the quoted figure is within the range of ultra high carbon, it would be difficult to work in a forge, and in my opinion would be too brittle for use as a tool, for a short cutting blade it would work OK, but not for anything that was intended to sustain impact.
I would think that this material was produced in a low tech native smelt. Wootz? No idea, but not everything produced in a low tech smelt is wootz. I have a lump of similar stuff that was given to me by a local smith who does a smelt once a year, more or less as a social gathering, & that smelt contains all the odds & ends of ferric material he has accumulated during the past 12 months or so. |
A computer crash means I'll have to look through backups, but I do have XRF readings on the kard above and a few other wootz blades that I hope to share in a few days for comparison.
More important, in the meantime, Verhoeven's ground breaking paper The Key Role of Impurities in Ancient Damascus Steel Blades may be found at https://www.tms.org/pubs/journals/JO...even-9809.html |
Hello everyone,I wanted to follow up on the lab data I posted with a quick macro observation regarding the material structure, specifically for Lee Jones, Ian, and our active bladesmiths.Several members asked how this un-etched steel behaves visually given the heavy surface wear. To show you, here is an extreme macro shot taken right around the spectrometer's dark spark-burn mark.The blade flat is covered in aggressive, intersecting scratch lines from historical cleaning. However, when you shift the raking light angles under specific camera settings—completely free of any chemical acid etching—look at what happens to the matrix beneath the damage.The granular crystal matrix—the dense, white carbide "snowflake" nodes—flows completely continuous and uninterrupted straight through the mechanical scratches. The pattern doesn't break or wash out at the scratch walls.Because this is an authentic, pre-industrial crucible steel volume containing 1.500% Carbon and a 0.013% Vanadium catalyst, the micro-crystals are tightly packed deep inside the core of the metal. No amount of surface scratching can erase them. They naturally react to different light angles and reflect light independently from the surrounding iron, creating an internal watermark that proves its true antique pedigree.I would love to hear your thoughts, especially from Lee, on this sub-surface pattern persistence and how it fits your theory regarding this being a salvaged high-status historical blade.Best regards,Oiluj13
Oiluj13,
Than you for your continuing pursuit of this blade's structure. I do have a couple more ideas. I suggest that you look at the Knife Steel Nerds online site. Larrin runs the site and is an excellent resource on knife steels--he is a true scientific expert on the subject. I would recommend becoming a member of the site (it's free). Larrin has responded to my questions and is very helpful. I'm afraid I can't comment on your latest data. The blade has a lot of surface pathology (grind marks, oxidation, etc.) that prevent me from interpreting much about its composition. If it were my knife and I wanted to know mor about its steel I would grind out all the marks and polish it back to white. Then I would do some controlled etching with a variety of solutions to determine which one best showed the crystal structures and other features. Nital is a good etchant but hard to get unless you are an analytical chemist or academic (and it can also be explosive in sufficiently high concentrations). Ferric chloride solution is quite good and I start at a 1 in 10 dilution of a commercially available solution from Radio Shack, moving up to 1 in 5 dilution if necessary. It is acidic and stains skin and clothing, and any surface it contacts! Vinegar is okay bit often slow. Citrus fruits are also fairly slow and the pH varies widely making a controlled etch harder to achieve. Only after a complete cleaning and etching of this blade, with observation of the surface under a microscope, would I venture an opinion on its crystalline pattern. The irregular linear structures that you show in the most recent pics could be anything. It's possible they were caused by contact, either intentionally or accidentally, with an etching agent, or they might be irregular areas of oxidation. I strongly doubt this is a wootz blade, but to establish it is would require eliminating other more likely possibilities such as surface changes. Regards, Ian |
