Old 5th July 2025, 06:07 PM   #1
tom22
Default Moro kris , to clean or not to clean ?
I recently acquired this moro kris , I'm not sure what region it's from etc , but there is quite alot of rust , I have taken the light surface rust off with some steel wool ,but im wondering should I go further with cleaning ,or is it stripping it of its age and use ?
tom22 is offline   Reply With Quote
Old 5th July 2025, 09:36 PM   #2
Looks like a nice3 1920s Magunindanao kris. I would clean the silver - silver was meant to shine.
Also, if you cleaned the blade, re-etch it to have the laminations come out.
Old 6th July 2025, 01:41 AM   #3
Tom, I agree with Battara. The silver should be cleaned, as well as the white metal on the scabbard (hard to say whether this is silver, probably not--could be nickel, white brass, or tin). The blade justifies a thorough cleaning and etching as there is already a nice pattern visible.
Nice kris. As Battara noted, an early 20th C example.
Old 6th July 2025, 05:07 AM   #4
Interesting metal tab that is attached to the ferrule ring and laying on top of the gonjo .
Suppose it ever had a baca-baca stirrup once?
Sure looks like it did.
Old 6th July 2025, 08:12 AM   #5
tom22
Yes I wondered about this tab ,was it originally there to hold a stirrup in place , Also thanks for everyone's advice in cleaning the sword , I will do the best I can but looks like it will take alot of work , thanks
Old 6th July 2025, 09:29 AM   #6
Agreed with the others, clean it and try to give it a new baca-baca.
I would oil and clean the wooden parts with oil (linseed, olive..) and polish the metal parts. I also would clean the blade further and like suggested by Jose and Ian etch it.
Old 6th July 2025, 08:02 PM   #7
tom22
Well I've given it a good clean , the silver came up well and the scabbard, but the blade needs more work than I thought , I havnt etched the blade yet because i think it needs to be cleaner to see any pattern , I'm not sure whether to carry on with it as it will take so much work to sand it down , I wouldn't use a machine sander as I know they can distort the shape of the blade ?
Old 7th July 2025, 03:31 PM   #8
Interested Party
Interested Party's Avatar
For really dry wood I've been experimenting with lots of almond oil. The wood just soaks it up because of its extremely low viscosity. Then after a few days to a week I add the coats of linseed oil.
Old 7th July 2025, 04:23 PM   #9
Jep, almond oil is very good!
Old 7th July 2025, 08:31 PM   #10
OH much nicer!
Old 8th July 2025, 05:04 PM   #11
tom22
Default Results after cleaning
Well thanks for all you advice,
I have cleaned the scabbard,and used olive oil for the wood,
Then i have sanded the blade with a fine grit wet and dry paper , it's took quite alot of work to get it looking like this ,I'm not sure where to stop,should I carry on sanding untill it's got rid of all the light pitting ? ,in general it looks alot btter
